06-09-2008 02:38 AM
06-09-2008 02:41 AM
MikeS81 wrote:
Hi jeyanthi,
i can´t find the original post, but here is another solution.
06-09-2008 02:43 AM - edited 06-09-2008 02:44 AM
06-09-2008 02:45 AM
parthabe wrote:
Did you mean that you cannot get/read this link?
06-09-2008 02:47 AM
Jeyanthi,
Dont keep repeating the same que even after you have got the clearest of the answers.
Read the text file into a Str indicator, convert it into a Str Arr [1D or 2D based on your file contents], then rip the corresponding column [if it is a 2D Str Arr], do a search & delete operation for the required element inside a while loop, stop the loop if the condition that all the instances of the required element are removed from the array and then stop the VI.
I hope this is clearer than the diagrammatic explanation of Mike.
After all, a picture is worth a 1000 lines.
06-09-2008 03:06 AM - edited 06-09-2008 03:09 AM
jeyanthi wrote:
i get the data frm text file and pass it to array. let say my array is like this
abc
cde
abc
cdeok let say i wana remove the cde from the text file to..how can it been done?
06-08-2017 04:00 PM - edited 06-08-2017 04:03 PM
Hey MIKE I just built the exact same block diagram that you have posted because I am wanting to resolve a similar issue but I keep getting error 74, does it appear that anything is wrong with mine?
Thx,
Sam
