06-08-2008 10:58 PM
06-08-2008 11:52 PM
Hi jeyanthi,
how do you mean it? If you want to remove them manually, right click on the element, select data operation and remove element. Or do you mean with a part of code?
Mike
06-09-2008 01:00 AM
06-09-2008 01:12 AM
Hi Jeyanthi,
See this link to not only remove all empty elements from an array, but also 'any' repeated element from an array.
Wire an Empty String Constant to the Element to Remove variable in that VI & it ll do the job for you.
06-09-2008 01:41 AM - edited 06-09-2008 01:42 AM
thk u it just simple only...
need another help
i get the data frm text file and pass it to array
let say my array is like this
abc
cde
abc
cde
ok let say i wana remove the cde from the text file to..how can it been done?
06-09-2008 02:01 AM - edited 06-09-2008 02:03 AM
Hi jeyanthi,
i can´t find the original post, but here is another solution.
Mike
06-09-2008 02:04 AM
06-09-2008 02:07 AM
06-09-2008 02:24 AM
06-09-2008 02:31 AM - edited 06-09-2008 02:32 AM
