-The way I connect my computer with internet is with "Get an automatic IP" connection configuration, so my IP is never the same.
-The file created by labview was modified by adding the line.
When you create the file in labview it gives you an URL with the name of your pc and the name of the vi file (http://kulilin/Untitled%201.htm) something like this. What I read is that because I didn`t have an IP that could be found on any web browser, I linked my IP with the provided with no-ip.com.
If your type of connection let you find your PC IP in any web browser maybe you can just type the URL given by labview.
Regards.
