01-28-2013 07:01 AM - edited 01-28-2013 07:05 AM
Solved it,
I can use string to fractional number!
I have a 2D string array from a multicolumn list box, and i want to check if every value is valid number, the numbers can be a single and can have negative values. Does anyone knows which regular expression i need to check this, or is there an ever better way doing it?
Thijs
Solved! Go to Solution.
01-28-2013 07:05 AM
solved!
01-28-2013 10:00 AM
You shoudl post your solution so others who have a similar issue can learn from how you solved it.
01-28-2013 12:41 PM
