06-21-2015 10:15 AM
Thank you a lot , finally it is working . I've added a write measure file (for later analysis) , and the "String to Byte Array function" .
what im planning here , im sampling lung sound using arduino and sending it to labview , now im training with serial communication later i will use XBee.
I have few more questions :
1. my first 8 bit in the array are "START" and the last 8 are the "END", is there any option to make the VI work on "IDLE" and listen to the port , only if the 8 start bit recevied , continue receive data until the 8 end bit recieved , and then stop.
06-21-2015 10:31 AM
06-21-2015 10:39 AM
im sorry , but it just hard for to understand what do you mean , can you try explain more simplely .
06-21-2015 10:48 AM
06-21-2015 02:10 PM
Ok , i will try to found out how to implement it , thank you for everything/
