10-11-2013 01:11 AM
I am having an input array in which i am reading data from csv file, i want to rearrange the data, so as to present it in presentable format, i have tried some operations but not getting exactly how to do.
below i am attaching the vi which contains the input array and the expected data.
10-11-2013 04:49 AM
Hello Ritu,
Here is one of the ways to do what you have described.
Let me know if this helps.
Chinmay
10-11-2013 05:11 AM
Hi Ritu,
how about this:
Alex
10-11-2013 05:53 AM
Hi Chinmay_NI
thankyou for your solution,
the output is coming as expected but one issue is that I cannot give Vbat and other parameters as constant in search 1D array as these names may vary depending on the test, and second thing is as i am reading the data from file in input array we might have verion number and other basic info again in program, i eill try to sort out these issues.
Thankyou
10-14-2013 10:47 PM
Chinmay_NI
I am getting one problem in the program, the solution you posted is working fine for me, but the problem is that i am having larger set of data in input array in which i am having version number and other things more than once and Vbat and othe things are also not constant i tried to fix these issues but stil not getting the result as expected, if you can help me i n sorting out this one issue
Thankyou
below i am attaching program,
10-15-2013 12:59 AM
This is how i am trying to modify the result but not getting the correct output, i might be following wrong approach, please help me in this data formatting.
10-15-2013 01:00 AM
Can you upload the code 2011
10-15-2013 01:05 AM
Thankyou Ranjeet_Singh for the reply,
here i am attaching the code in LV 2011
10-15-2013 01:22 AM
Hey Ritu,
Can you let me know the expected input and expected output?
thank
10-15-2013 01:24 AM
expected input i have kept as constant there in block diagram the array for expected output is alco there with the name expected data
