Reply
reading timestamp from column in txt-file
Go to Solution
hi labview pros
i'm working with labview 8.6 for about 1 week and i need some help with reading txt-files.
the textfiles i have to read have 2 - 11 columns.
the first column shows the time and the others show different channels from which i measured voltages.
so, there is no problem with reading the voltage-columns, and put it onto the y-axe in the vi's graph but i can't get the time-column on the x-axe.
i took the basic "read from text file.vi" and modified it a bit according to my needs.
hope you can help me, getting the time column on the x-axe. (maybe with a xy-graph???)
the vi and txt-file i have to read are attached...
Message 1 of 9 (2,059 Views)
Reply
Re: reading timestamp from column in txt-file
You can right click on the grapg axis and select 'formatting'.  In the pop-uo select absolute or relitive time, add the 'container' and then select what you want to display.
Message 2 of 9 (2,051 Views)
Reply
Changing the formatting does nothing. There is nothing in the data that can be used. The x axis would just default to a t0=0 and dt =1.
You could create a waveform data type and use the first time value as t0 and the sample rate as dt.
Message 3 of 9 (2,036 Views)
Accepted by topic author fr33k
‎08-27-2015 06:09 PM
Here's an example. The formatting of the x axis to relative time will now do something.
Message 4 of 9 (2,032 Views)
[ Edited ]
i allready tried this option but it brings an incorrect result.
maybe you mentioned that with this option, every value in the graph gets a time of 1 second.
for example, the fourth value is at 01:00:03 (red line).
but in the txt-file the voltagevalues have a space of 4 seconds inbetween. so the third value should have a time of 12 seconds (cause first value starts at 0)
but thx for first reply!
Message Edited by fr33k on 09-16-2009 03:21 PM
Message 5 of 9 (2,025 Views)
Reply
Here is what I would do.  I created a second selection table for the x-axis and got it to format correctly for you.  Now you can plot any channel against any other channel - time included.  For this purpose though, I assumed that your x-axis selection would be time.
John Niezgoski
Signal.X Technologies
Certified Developer
Message 6 of 9 (2,016 Views)
thx for all your replies!
@dennis knutson: thx for the example-vi. i combined it with my vi and it worked fine. thats exactly what i was looking for!
@johnski: thx also for your solution, i think it also would work but it's a bit going to far for my needs. good work anyway. maybe i can use it in a next vi.
Message 7 of 9 (1,987 Views)
Reply
Can you guys save it under 8.5 version. I would like to see it too. That could really help in my project. Thanks!
Message 8 of 9 (1,723 Views)
Reply
Message 9 of 9 (1,694 Views)
Reply
