06-22-2015 01:40 PM
Im trying to read in a wave form from the lecroy 9314A Oscilliscope and plot its spectrum. Attached is one of my vi's but it isn't plotting the correct spectrum
06-22-2015 05:30 PM
The first question to ask is are you getting any data in from the Oscilloscope? [This is the old "Is it the Hardware or the Software" question]. If you are getting a reasonable-looking Waveform in from the Hardware, then the problem is your Software, otherwise it is the Hardware.
Hardware first: If the WaveGraph wire is empty (or when you connect it to a Graph to see its contents, it looks "wrong"), try to use MAX's Test Panels to send GPIB commands to the Scope and read the Waveforms into MAX. Maybe it's simply "a Failure to Communicate".
On the other hand, if you have a good Waveform, then it's probably the Software. Simplify, Simplify, Simplify. Write a tiny Test VI using a "synthesized Waveform" (such as random numbers, or a Sinusoid from a Wave Generation routine) and test one or two of the steps you have in your larger program. Find where it "breaks" -- it is simpler to fix code with basically a single straight Wire path and 3-5 functions than one with multiple wires and functions.
06-23-2015 10:41 AM
my waveform looks correct so im assuming its a software issue. The bulk of my code i got from an example built into labview that has preset waveforms that work.
06-23-2015 12:17 PM
This is what i get for a result for 1kHz sine wave but no matter what i change the frequency to the bar does not move from the bottom.
06-23-2015 02:18 PM
06-29-2015 11:47 AM
i figured out my craph only works well for in the Mhz range and i had it working last week come back today and my charts for somereason are not updating correctly and im trying to refresh their memory
