How do I read a soap out parameter from a .net method? Although displayed in blue, when I right click on the method output with the wiring tool the method and property options are greyed. Creating a indicator only results in a .net box on the front panel.
What constructor do you have selected? Are you getting a compile error from the constructor node itself?...because if that is not valid you would not be able to acces the methods and properties.
The counstructor is part of a locally developed web service. I can pass data to and get data from the method; however there is additional data in what is known as a "soap out parameter". When I invoke the web method the data comes up as a reference; however I cannot attach a property node to this reference to get to the data.
