read text from pdf
Is there a way to read text from a pdf file using LabVIEW? I've been trying using ActiveX but not getting very far.
PaulG.
LabVIEW versions 5.0 - 2020
“All programmers are optimists”
― Frederick P. Brooks Jr.
Message 1 of 14
(10,193 Views)
Hi Paul,
I found a similar forum with swveral solutions, see if any fits your needs.
Read text from PDF files:
http://forums.ni.com/t5/LabVIEW/Read-text-in-pdf-files/m-p/975808/highlight/true#M437420
I would recommend trying ptcoverter, which transfers a PDF to a text file, then, do the reading.
Have a nice day!
NavasMonk
National Instruments, México
ELP Support Engineer
www.ni.com/soporte
Message 2 of 14
(10,160 Views)
I searched and read through must of what NI has already before I posted the question. I saw this and a lot of other "solutions". I was hoping someone had something a little less clunky. Even a simple access to pdfdoc > SaveAs > Text would probably solve my problem.
PaulG.
Message 3 of 14
(10,151 Views)
hello PaulG
https://decibel.ni.com/content/docs/DOC-2163
you can try the above attached link and if you are not able to open or read a pdf document uding ActiveX then there is some problem in adobe reader, you might need to update your adobe reader to higher version.
Message 4 of 14
(10,132 Views)
Hi PaulG,
can you tell what is the error or problem coming while trying to read pdf with activeX.
Message 5 of 14
(10,129 Views)
I'm not having any problems opening a PDF document. I want to get the text out of it.
PaulG.
Message 6 of 14
(10,107 Views)
Hi PaulG,
sorry i am not getting you, you want the text in what format, means you want it to be displayed on front panel in indicator or is it something else.
Message 7 of 14
(10,101 Views)
Yes. I can open the PDF file but cannot get the text from the PDF file into a string control.
PaulG.
Message 8 of 14
(10,063 Views)
Accepted by topic author PaulG.
I posted something on the Light Side a few years ago - http://lavag.org/topic/12228-pdf-extract-text/?p=73553
I was trying to read serial numbers from a directory full of pdf test reports.  It worked.
Jim
Message 9 of 14
(10,058 Views)
I'm linked to the pdfbox dll in the vi but no methods are listed in the constructors. I can't change anything in the  vi. Like I said I was hoping for something a little less clunky. Incidentally this has to be written in 8.5. I hope this is not part of the problem. Thanks anyway for your help.
PaulG.
Message 10 of 14
(10,001 Views)
