10-30-2014 12:55 AM
Dear qudoe
i am trying to make one programme in labview which challenge me to fight with a time.
here i am attaching my labview code in which i have one data file, which consists 500 columns from that i have to find min value and max value from every column.
i tried my best but it takes 30seconds to find min and max value from every column.
i want to perform this operation within a second.
so can any one suggest me any correction required which can boost my program.
10-30-2014 01:17 AM - edited 10-30-2014 01:17 AM
You don't have to open and close the file all the time and also you don't really need a while loop to do this. Check the code attached.
Certainly you can still optimize it to get better performance, I just made a quick draft to show you how simple it is.
10-30-2014 01:59 AM
ok
thanks a lot it works very fine
