06-01-2011 10:58 PM
hi,
i am read an excel file approx 15 rows by 16 rows.
The vi works fine upto 5 rows and 5 columns and prints data on front panel after using data variant.
The Cell range are also seems to be correct for higher rows/columns but then the errors occurs at data variant to 2d dbl stage.
Any idea what might be wrong in the vi
chintan
06-01-2011 11:38 PM
We can only guess at what might be wrong with the VI since we can't see it because you didn't attach it.
06-02-2011 09:46 AM
Thanks for the reply.
I found out what was wrong the data types should be the string type and i was using DBL.
