I've build a VI to read all sheets in an Excel file. It works well but when I'm using it in another VI and that I access the same Excel file, for example with the delete file VI, an error is generated. If the two VI are used separatly, no problem occurs.
I attach the VI I'm using to test the availability of the Excel file after the read operation is completed. The erasing of the file doesn't work, but some other actions can't be done too (save, etc.).
It seems as if an opened reference is not closed (even if I've tried to do to my best to close them all !)
I know the report generation toolkit exists but we don't have any money to spend in this solution that don't correspond to our needs.
I'd be grateful if someone could tell me what is going wrong in my VI, it's been a long time I've been trying and all my ideas failed for the moment...
Thank you in advance for your help.
Bim
