04-14-2009 09:52 AM
What you have there looks like it should not cause any problems. You could put the whole program in a while loop so you can do repeating tests. If you know how many tests you are going to do you can put it in a for loop.
I still recommend putting the middle section in a sequence structure if you have not already done that.
04-15-2009 09:19 AM
Izze2000 wrote:However if i do not change the input device the new OK button works fine, but if i change the input device suddenly the is no response trying to klick on the new OK button?
When highlighting the Execution i can see that the program loops around the new OK button in th while loop as expected,but for some reason there is no response of the new OK button in the Front panel?
What could be wrong?
Your VI stops working because the functions in the "Initialize" loop is not made for extensive repeated calling. Doing this will bring the Labview sound system to its knees. It will stop working. You should never use while loops this way. If your while loop is waiting for some kind of user interaction always insert the "wait ms" function. Set the "milliseconds to wait" as high as possible without risking a degrade in the performance
04-18-2009 06:36 AM
10-26-2010 11:59 PM
Coq Rouge, thanks for all your input on this.
One thing I have noticed, if the buffer size is more than 4 times the size of the samples read at a time, it will slow down the front panel updates.
10-27-2010 07:28 AM
I think I reported about that error here
But I have no expectation that it will be fixed. NI do not care about the sound system at all. NI attitude against the user of sound the sound system is extremely arrogant. No errors have been fixed since Labview 8.5. But instead they have managed to introduce new errors. I use only this system now
http://www.zeitnitz.de/Christian/waveio
