NI Home
Cart Cart | Help
Hello Events Academic NI Developer Zone Support Solutions Products & Services Contact NI MyNI
You are here:
NI Home > NI Developer Zone > NI Discussion Forums
Reply
Member
aduley
randomize array
Hello all!
Does anyone have or know of a link to a VI that will randomize array
elements?
Aaron
____________________________________________
Aaron Duley / aduley@ufl.edu
Motor Behavior & Performance Psychology Laboratories
http://www.hhp.ufl.edu/ess/mblab
Department of Exercise & Sport Sciences
College of Health & Human Performance
University of Florida
(352) 392-0580 x1378
100 Florida Gym R-132-D
PO Box 118207
Gainesville, Fl 32611
Active Participant
Greg_McKaskle2
Re: randomize array
> elements?
I don't have a VI, but I can describe how to build one pretty quickly.
The key is to select an array index and swap it with the last element
of the array. By swap, I mean index both and replace them with each
other. Then do the same operation, select a random array from the
elements ignoring the last, and swap it with the next to last. Do
this swap with another element of the array and statistically, you
are shuffled.
In more detail:
If your array length is N, indexed 0 through N-1, the first thing to
do is generate a number R, between 0 and N-1. Index two elements
from the array, R and N-1. Write the values back to the two
elements, but reversed. Next iteration generate a
number between
0 and N-2. Index with R and N-2, and swap.
You can do this with a For loop. Wire the array into a shift register.
Compute the random number from Array Size - 1 - i.
Greg McKaskle
By using this web site, you accept the Terms of Use for this web site. Please read these Terms of Use carefully before using any part of this site. Please go here for information on ni.com's copyright infringement policy.
My Profile | Privacy | Legal | Contact NI © 2011 National Instruments Corporation. All rights reserved.    |    E-Mail this Page E-Mail this Page
