04-21-2009 12:13 PM
Dear labview gurus,
I have a problem that I would
like some help with. I have a labview VI that creates an image using
the "IMAQ image" block set, and I have a VI that allows image selection
with the mouse. Most of that second VI's code comes from an example.
The problem is, my picture selection VI requires that the picture be
the "picture" data type, but the pictures my other VI creates are the
"image" data type. Ctrl-h says the first type of wire is "picture" and
the second type of wire is "Image Dst Out (IMAQImage)". I either need
to convert the "image" to "picture", or rewrite my picture selection to
take in an "image" variable instead of "picture." I'm not especially
good at labview, and I'm running out of time, so conversion seems to be
the best option. I found another thread that talks about converting an
"image" to an array, but I'm not sure how to turn that array back into
a "picture". Does anyone have any ideas?
sdt51
04-21-2009 03:39 PM
Hi sdt51,
You can use this to do what you're trying to do.
Thanks!
04-21-2009 07:11 PM
Hey Stephen,
Thanks for your reply. I saw that VI when I was digging around, but there are a couple issues. First, I'm using v8.2 and that VI is v8.6. More problematic, however, is that fact that I need to go from image to picture, not picture to image. Would it be possible to "reverse engineer" that VI to make it convert the other way?
Daniel
04-22-2009 08:34 AM
Hi Daniel,
The VI that I posted actually did the right thing, but I misnamed it. Where did you see this VI? I just created myself on my PC here. Regardless, here's the same VI in 8.2.
04-22-2009 03:51 PM
Hey Stephen,
Awesome, thanks. I'll try it out tomorrow when I get to lab and let you know how it works. The other VI I was talking about was one I found here: http://decibel.ni.com/content/docs/DOC-2209 but as I mentioned, I need one that goes the other way.
Daniel
