You are plotting a single point at a time, and you do not record previous data. Since your graph cannot draw a line between a single point (??? :))), you should set up the graph to display the point as a dot. That way, you will see something moving !
Not for a long time however, since there is nothing in your code to return the "scope beam" to the origin...
short advice : use a chart instead of a graph, and select the scope display mode (right-click on the chart, then "Advanced... > Update mode"). Adjust the chart history length to the number of points you want to display (again right-click).
Chilly Charly (aka CC)
E-List Master - Kudos glutton - Press the yellow button on the left...
