05-03-2007 08:20 AM
05-03-2007 07:43 PM
03-29-2017 08:32 AM - edited 03-29-2017 08:33 AM
Here you go.
Wrote it in Watlow C in 1990 highly optimized for speed to handle both increasing and decreasing values. Been using it for 27 years... This is the 2011 Version, but it has up-compiled through every LV version through the years (since 3.2?)
03-29-2017 08:39 AM
You should have waited another month and you could have been 10 years behind!
03-29-2017 09:34 AM
: ) Always surprises me how these old threads still come up during searches and yet sometimes remain unresolved, figured I'd throw this nugget to the community. Since I wrote it in 1990, it was 17 years ahead of it's time, way before forums & blogs, I think the Watlow C Compiler is long gone. I'll bet there are still people struggling daily without a good solution such a basic problem. and NI has yet to alter the base functionality of the VI. I am surprised I haven't seen an Open G function over the years, but this one is a Windows only CIN.
Easy enough to compute, but difficult to execute in an optimized manner especially with large arrays and multiple iterations since this particular function is likely to be hammered - it better be as efficient as possible. I ran this CIN through heavy speed trials back then, it is one of my most used functions in sig analysis and measurement mainly because of the beautiful fractional index for interpolated accuracy!
03-29-2017 11:08 AM
I was surprised to see this pop up again too, it's one of only a dozen or so threads I've ever started here.
At the time I posed the question, I had the understanding that the LabVIEW function 'Reverse 1D Array' would literally swap all the elements around in memory. Some years and versions of LabVIEW later, I learned that several array operations like Reverse, Transpose, maybe others could perform much more efficiently. Now they would would just attach some metadata to the array so that subsequent processing could treat it *as if* it were Reversed/Transposed/whatever, but the elements wouldn't literally get moved around in memory. I don't honestly know when that more efficient treatment got introduced, whether before or after my original question.
I *did* end up using the binary search algorithm, sorry I never posted it. But I now know that there'd be a memory efficient option to do Reverse->Threshold->Reverse which would have sufficed back in the day, if it was valid then and if I had known about it.
I agree it's odd that the built-in function still doesn't inherently support decreasing data.
-Kevin P
03-30-2017 09:22 AM
Right? I don't even understand why the threshold needs increasing values. My Optimized Watcom C CIN is simply traversing the array forward riding ASC/DEC direction both up and down until it finds the target between two values and returns the fractional index (or the limits). A binary search needs to be sorted or in order, not sure how one would find a target value of unknown data content without first sorting the data, which is a large time hit. Originally I had played with G only array reversals also, but needed something lightning quick & efficient. Given that both the threshold and interpolate are such critically needed functions for evaluating a linearized guess between available data points, it made sense to implement low level. Maybe the array reversal is fast enough now, that was back in LV 3.0.1 (93?) back when the bulldozer was a scary icon of impending doom.
it was probably the last C app I wrote before giving my soul over to LabVIEW : ) I
03-31-2017 09:29 AM
I feel like at any moment Altenbach will come in and demo some G solution that is crazy efficient and some how implements it with imaginary numbers, or some other crazy function I never use. He's got a knack implementing very efficient G code and I'd be curious if he can make a similar function in pure G.
Get going with G! - LabVIEW Wiki.
16 Part Blog on Automotive CAN bus. - Hooovahh - LabVIEW Overlord
03-31-2017 10:43 AM
Well, to be fair, back in the thread's original era he already *did* suggest the winning idea...
-Kevin P
