I found the solution to my previous problem. I had the "Open file" tool placed inside a stacked case structure that continued to loop (this case repeats itself while it waits on an operator to select a push button).
Now I have my logic set up pretty much like yours, but when I added a path name constant to the path name it no longer created anything! This file stuff is rather annoying. All I want to do is create a new file, and continue to append new data to it as my project runs. If I leave the path name blank so it prompts me to "save as", it will create the file, but only put in the first line.
I'll try to paste some sample code, but my program is pretty large and the file write tools are placed in different cases in my stacked case structure.
Amateur programmer for over 10 years!
