04-23-2015 01:40 PM
Yes, I verified that this is fixed in 2015 as well.
04-27-2015 11:44 AM
Moved from here where it had no business.
Not sure we already discussed this one:
Ctrl-Space Ctrl-R gives this:
Not sure about the logic? I definitely did not expect it.
04-27-2015 12:10 PM
Further up this thread we agreed that if Remove and Rewire was performed on a function with a single input and a single output, that a pass-through wire would be created, regardless of data types. I believe the logic was that, if you didn't want the pass through wire to be created, you'd press Delete instead.
So the behavior you're seeing is intended, per previous discussions.
04-27-2015 02:29 PM
I need to refer to that discussion again: what post was it?
I suspect there wasn't any type incompatibility as is obviously the case here.
04-27-2015 02:40 PM
04-27-2015 02:51 PM
Darin. K's post 6?
Fair enough.
It is called Remove AND Rewire for a reason I guess!
08-19-2015 07:35 PM
Here is a case of CSCR doing something I am a bit disappointed by:
when "of course" I was expecting this:
Connecting the Boolean wire to the For Loop iteration number doesn't make sense, I agree with that.
However, connecting the single blue wire would seem natural, as it is the only other source.
I agree that if the Select primitive had had more than one source wire, there would have been ambiguity.
However, notice this:
So what gives?
08-20-2015 12:57 PM
Hi X.
I'm not sure what you are asking. Are you asking if the number of iterations is wired, or why the number of iterations is wired to 1?
08-20-2015 02:01 PM
X. wrote:
So what gives?
The Remove and Rewire algorithm gets incremental improvements with each LabVIEW release. I'm not sure which version you're using, but in LabVIEW 2015, the operations appear to behave as you desire:
08-20-2015 02:48 PM
@Darren wrote:
X. wrote:
So what gives?
Cool. One more reason to schedule an upgrade. I tested this in LV 2013 SP1.
