"Lookup table" with interpolation
I have an Excel chart which has x- and y- value (x is voltage, y is speed). I want to implement a lookup table in LabVIEW:
- store this x-y chart in VI
- and when user key in a x value, the VI should find a corresponding y value (interpolation is to be implemented).
Essentially this is a LUT with interpolation.
How can I do this? Any example?
Thank you..
(2,919 Views)
Hi splee,
wow, there's a ready-to-use function in LabVIEW...
(2,911 Views)
See attached ( LabVIEW 8.6)
Now is the right time to use %^<%Y-%m-%dT%H:%M:%S%3uZ>T
If you don't hate time zones, you're not a real programmer.
"You are what you don't automate"
Inplaceness is synonymous with insidiousness
(2,883 Views)
Side comment: You can eliminate the two bundle nodes by using "build cluster array".
(2,877 Views)
