11-22-2015 05:29 AM
I have been trying to let Labview send an SMS to my smartphone, only I keep getting Error 363513: "An error occured while sending data on the network". Does anyone have an idea what "An error" could mean, and how I can solve it? I've been struggling with this for quite a while...
Thank you !
11-22-2015 09:31 AM
Suppose I told you there was a big mistake in a book, but I only was going to show you the cover, tell you the nature of the mistake, and ask you how I should fix it. That's what you've done, asking us what "an error" could mean, but without providing to us the code that gave rise to the error. Post your VI -- you do not have to post the values you blacked out on your Front Panel, but we do need to see what functions you were using, as one of them gave rise to the Error, and we don't have any idea which one(s) you used. We could also try running your code ourselves, and could maybe figure out how to make it work ...
P.S. -- attach the actual VI(s), please. If there are too many, put them all in a folder, compress the folder, and attach the .ZIP file (this is an excellent way to submit a LabVIEW Project).
11-22-2015 09:17 PM
Hello Annabel2001!
First off, thanks for posting! I noticed on the front panel of your VI that the text for the Outgoing Mail Server was "smtp". I believe that the error you are getting is related to the fact that this is not a valid server address. As you can see in the example that you are probably building off of, you will need to use a server address in the form of smtp.[hostname].com such as smtp.google.com.
https://decibel.ni.com/content/docs/DOC-35093
I think putting in a valid address will solve your issue. Let us know if you're still running into problems.
11-22-2015 10:23 PM
03-17-2017 05:00 PM
I wanted to note this because I had not seen this response elsewhere.
When using the 'Set Recipients' .vi using and feeding in an array that contains blank strings among valid emails, I have received this same error (Error 363513 occurred at LabVIEWSMTPClient.lvlib:Send).
