NI Home
Cart Cart | Help
You are here:
Reply
Active Participant
lavalava
Accepted Solution
quick question misplaced graph label panel color
Hi All,
I have 2 quick questions but couldn't find it in the search, maybe I wasn't hitting the right keyword.  Anyway.
1.  How do I move the label "Interval" back to center and have it stays at center at all time?
2.  Is there a way to programmically change the panel background color?
Proven Zealot
Re: quick question misplaced graph label panel color
Hi lavalava,
point 2 is easy:
Open a reference of the panel, wire it to a property node and select "Color"...
CLAD, using 2009SP1 + LV2011SP1 on WinXP+Win7+cRIO
Kudos are welcome :smileywink:
Active Participant
lavalava
Gerd,
Where do I find that option cuz I don't see it?  I get an empty array too:
Could I please get a screen shot or vi saved as 8.6 from you?  Screen shot is easier.  Thanks
Proven Zealot
Hi lavalava,
sorry, I just used LV7.1 to verify my suggestion.
Starting with LV8 you have to use the panes. The first pane will (most likely) be your panel and exhibits your color setting...
Active Participant
lavalava
[ Edited ]
Gerd,
I did dugged through Pane[] too but couldn't locate BG Color setting anywhere.  Decos[] was only place that lets me set BG color but it keeps returning null array so I wasn't able to set it.  I'm sure it must be hiding somewhere, where could it be...
Proven Zealot
Hi lavalava,
panels/panes don't have a BG color - they only have a "color" property. Can you tell me the difference of foreground and background for the pane(l)?
Trusted Enthusiast
Darin.K
If you right click on the scrollbar of the Front Panel you can Right-Click->Create Property Node->Pane Color.  You will get a single property node nicely linked to the proper pane.
Active Participant
lavalava
Okay #2 was answered. Thanks, Darin.
So how about my question #1, is there a way to move "interval" back to center without creating a new graph?  I kept running into this problem so creating new graph everytime isn't a good practice.  There has got to be a way to prevent LV from doing that.
Trusted Enthusiast
Darin.K
If you want to keep that label centered you can use the following:
My Profile | Privacy | Legal | Contact NI © 2011 National Instruments Corporation. All rights reserved.    |    E-Mail this Page E-Mail this Page
