The attachment to this post was written in LabVIEW 7.1 and NI-DAQ 7.2. This example has not yet been released to our online forum, so there is a chance that it is not yet complete. You may have to do some programming yourself in this VI depending on the performance you are seeing.
Here are the preliminary instructions:
The NI-DAQmx driver allows you to reprogram the counters on the fly during continuous pulse train generation. This means that you can change both the number of pulses per second and the pulse-width while pulse train generation is in progress without glitching.
The attached example program demonstrates this capability. It can be used with E Series or 660x devices. The accuracy of the pulse train frequency and duty cycle
is limited only by the resolution of the internal timebase. You may choose any timebase supported by your device. The timebase you choose determines the range of frequencies you may produce.
A Note on Accuracy:
For E Series devices, there are two timebases available, yielding a counter resolution of 50 nanoseconds or 10 microseconds. For 660x devices, there are three timebases available, yielding a resolution of 12.5 nanoseconds, 50 nanoseconds, or 10 microseconds. If the pulse train specification you desire is evenly divisible by the timebase, then you can achieve within about 0.01 percent of the timebase on E Series devices or within about 0.005 percent of the timebase on a 660x device.
Best Regards,
Jared A
