03-11-2013 05:05 PM
hi everyone
I wanted to select for example 2 input and even if one of two buttons is not zero the program still works.
My program works but I do not know why LEDs flash ??
03-11-2013 05:42 PM
Its Straight forward since your Push button is true the true case is getting executed if that is false nothing happens. What do you want to achieve in your program?, if you can explain then it would be good
03-11-2013 05:52 PM
emmm it look like just a test i want to know how i can use push button so i realsed that programm!!
my programm said if i push commande and capteur my two LEDS should works but reset commande i stiil have those two leds work but when i resert capteur the two leds shouldn't works
03-11-2013 06:47 PM - edited 03-11-2013 06:48 PM
Please show us what you do and in what order you operate the controls. What do you observe and what you expect to see instead.
