04-17-2016 07:48 PM
Hello everybody,
I am trying to generate pulses and I used attached vi for that. Actually I write this vi using help from this website. The default amplitude (voltage) here is 5V. Can anybody suggest me how to vary amplitde? I mean, how to make the amplide like 7V or 8V ?
Thank you in advance
04-18-2016 02:08 AM
Hi keshu,
As you are using a digital (counter) output you need an additional amplifier to change voltage levels…
(This is basic electronics and not related to LabVIEW!)
When you want to solve this with just LabVIEW you need to use an analog output to output waveforms…
04-18-2016 03:56 PM
Thank you GErdW. As I suggested I write analogue output as attached. Can you please look at it and suggest me what did I miss because I am not getting output..
04-19-2016 02:00 AM
Hi Keshu,
In this case you should get an error message. Do you?
- Why do you use an ExpressVI to create that waveform? There are easy-to-use functions in the signal generation palette!
- You don't set any timing for your DAQmx task! How should the waveform output work then?
Did you examine the example VIs coming with LabVIEW and DAQmx? There are examples on how to output waveforms!
