Use the "Protect my pressure transducer" vi in the "Measurements palette". Seriously, labview is software, you really want to be protecting physical things (hardware) with more hardware.
Do you know that the diaphragm of the pressure transducer is electrically attached to the reast of the circuit?
Sheldon
Technical geek, engineer, research scientist, biodegradable...
