property node - help needed
hello 🙂
here again 🙂 instead reading in chunks i have to read only a part of file..
i have some questions...i think about property nodes...
i would do this:
check if a file is bigger than a particular size
if is bigger than this size i would that appears a window in which a user can select which part of file would read (#part=filesize/#mysize + 1 in some cases)
if file size is < than my size, no windows selection and my program continue
my questions are:
-in which way can i make a window appear
-in which way can i make a selection and pass the index selected
i have done as in attachment but it doesn't work, in false case i put value = 0
Using LabVIEW 7.1
(2,050 Views)
This is how you can make a new window appear.
There is also the possibility to do it with a tab control making it (un)visible
Koen
UnCertified LabVIEW Student
Mistakes are for learning, that's why suggestions are always welcome!
(2,026 Views)
