NI Home
Cart Cart | Help
Hello Events Academic NI Developer Zone Support Solutions Products & Services Contact NI MyNI
You are here:
NI Home > NI Developer Zone > NI Discussion Forums
Reply
Member
NewCLAD
progress bar
y want to show a status bar who will be closed after the operation. The operation is a flashing in memory who is done by a DLL function called in labview VI.
Thank you for your help!!!!and have a nice christmas
Active Participant nyc
Active Participant
Re: progress bar
LabVIEW 6.1 has various progress bar displays for the front panel under Controls -> Numeric.
Create a property node for the progress bar display you are using.
And set its Visible property to true at the start and to false at the end
the only uncertain is how you will know how much of the "flashing of memory" has occurred.
Is it a set time?
Member
RJay
Re: progress bar
Most FLASH programming tools/software return a value that can be used for progress. Usually it is the number of bytes programmed thus far. Some (like Tornado VisionClick) allow functions to program in smaller steps (within a loop). In that case, you can provide a value to a progress bar.
So there might be some math involved.
Trusted Enthusiast
chilly charly
Re: progress bar
I suppose that you can get an estimate of the time required to flash your ROM from the size of the code.
Then you can start a parallel loop to move a progress bar. Use a time slightly larger than your estimate. Stop the loop when the flash is finished.
See the attached vi
You could also run a dedicated vi dynamically, but that's another story ! :smileyhappy:
Merry Christmas and Happy Wiring
CC
Chilly Charly    (aka CC)
         E-List Master - Kudos glutton - Press the yellow button on the left...
Member
NewCLAD
Write in a configuration file
Hi, happy new year to everyone!!!!
I need to modify a Configuration Setting file and for that I use the VI: Write Characters to file.vi available in the function panel but the problem is that the new file generated has a size of 1.83Kbytes instead of 1.81Kbytes despite the fact that this two files had exactly the same contents
I remenber you that I use Labview7.0.............Thank tou very much and best regards
Trusted Enthusiast
chilly charly
Re: Write in a configuration file
Probably better to post your question again... Nobody will go down here to help you !
May be you could attach both files in a zipped archive. Somebody could have a look and tell you were is the difference (if any...)
Happy New Wires !
CC
Active Participant
shoneill
Re: progress bar
On a side note, I do vaguely remember someone pointing out before that each bend in a wire on the block diagram of a VI takes up space. I believe it was 32 bytes. Sorry if I can't remember who posted the information originally, but I certainly do know I've been avoiding wobbly lines ever since.
Maybe you have the same functions and VIs on the block diagram, but some of the wires have been bent, moved or changed.
Hope this helps
Shane.
Using LV 6.1 and 8.2.1 on W2k (SP4) and WXP (SP2)
Member
NewCLAD
Thank CC!! bye
Knight of NI
Ray.R
Re: progress bar
/b shoneill said: "On a side note, I do vaguely remember someone pointing out before that each bend in a wire on the block diagram of a VI takes up space. I believe it was 32 bytes. Sorry if I can't remember who posted the information originally, but I certainly do know I've been avoiding wobbly lines ever since.
" /b
Say what?? you mean a simple bend in the wiring takes up 32 bytes.... each?? -wow-
So much for making the wiring look like a circuit card.. :smileywink:
This is good information to post. Maybe we should start a thread called "LabView: Behind the scenes" where we put tid-bits of info like this.
Thanks Shane & Happy New Year.
Ray
(starting to) See Life in a brand new way...
b* ^ )
Member
MonkeyKK
Re: progress bar
I have a problem on the progress bar. the progress bar keep coming up when i press stop. i Have already check the while and for loop.  Can anyone help?
By using this web site, you accept the Terms of Use for this web site. Please read these Terms of Use carefully before using any part of this site. Please go here for information on ni.com's copyright infringement policy.
My Profile | Privacy | Legal | Contact NI © 2011 National Instruments Corporation. All rights reserved.    |    E-Mail this Page E-Mail this Page
