10-23-2008 09:58 PM
10-23-2008 10:20 PM
indeterminate state,
what I meant here is that progress bar should not just idle but constant rocking back and forth the glider with a small block ....very similiar to how you normally see when you use your OS.
10-24-2008 12:04 AM
Are you talking about windows progress or anything. I am not able to understand. It will be better if you can explain in a better way.
10-24-2008 02:00 AM
10-27-2008 02:27 AM
