05-28-2015 06:11 AM
I am struggling to implement the attached model into the labview environment, my system is using inputs to my cRIO to determine certain outputs that will be determined based on the turbine model. I am assuming this should be done using the control and simulation pallete but I am wondering if anyone has potentially developed a similar .vi using a complex state space model as attached. Any assistance would be greatly appreciated. thanks.
05-29-2015 02:47 PM
Hi there,
The following tutorial provides an example PID application.
'Reference Design for Model Based PID Tuning'
http://www.ni.com/tutorial/9861/en/
The PID shipping examples in LabVIEW (in the 'Control and Simulation' directory in the Example Finder) are also good sources to reference. Hope this helps!
~ Q ~
