11-13-2015 11:17 AM
hello
I created a sub-vi that displays a configuration nodal window
depending on the condition (display or initialize) I don't want the front panel to display everytime
is it possible to insert a program inside the condition below ti determine during which condition the sub-vi have to be displayed?
thanks
Solved! Go to Solution.
11-13-2015 11:37 AM
Use an Invoke Node to make the front panel visible. The method is VI->Front Panel.Open. To close the front panel, use the Front Panel.Close method.
11-13-2015 11:41 AM
What is "nodal"?
Please attach your Vi instead of a picture? Is the current picture the subVI code or the calling code?
Don't hide event structures deep inside other structures.
11-13-2015 01:41 PM
ok, thanks. Itested and it is working
my picture above was the subVI diagram
below here is the same diagram with the addition of the invoke node
thanks for your help 😉
11-13-2015 02:16 PM
11-13-2015 05:51 PM - edited 11-13-2015 06:00 PM
Take a look if you want
