programmatically set NI DAQ physical channels
If I read channel assignment from a configuration file (e.g. 9205 AI0:AI1), how can I create DAQ tasks using corresponding physical channels in labview?
(5,235 Views)
So far what I come up with is
1. create a string constant array with channel names that corresponds to the all physical channels array one to one.
2. Read from configuration file and find the index in the array.
3. Index the physical channels array to pick out the correspondign channel.
The problem with this is I have to create a task for every single physical channel it picked, because I can't create the physical channels like when you use multiple selections in the Browse dialog box the way you typically do for a Physical Channel constant.
(5,228 Views)
You can call DAQmx Create Channel serially for each physical channel connecting your task reference into the 'task in' input so that all will be part of the same task.  Hope this is what you are trying to do.
Randall Pursley
(5,220 Views)
Accepted by topic author pellet8
see attached for a simpler attempt
Randall Pursley
(5,217 Views)
Thank you for the code. That solves the problem.
Can I typecast a string to a DAQmx Physical Channel? This will further simplify my program.
(5,214 Views)
You should be able to.  The code does it already at the input to the Create Channel vi
Randall Pursley
(5,210 Views)
