10-30-2007 08:24 AM
10-30-2007 08:42 AM
Epictetus
10-30-2007 09:03 AM
10-30-2007 09:10 AM
Epictetus
05-29-2009 03:17 PM
We're still having this issue with LV 8.6, and would definitely like to get rid of those empty text fields in Scaled Legend.
Is there a solution or workaround available since the initial post (back in 2007)?
Please advise - thanks!
05-29-2009 03:22 PM
We have the same issue as well.
I was wondering if the only way around this would be to create an Xcontrol. This would implement the scale legend functionality with your own set of buttons. Then replace all graphs with this Xcontrol.
I never knew what the use of those text labels is, and also always deleted them.
06-01-2009 10:14 AM
Jens at Lava forum gave me this tip, which works great!!!!
1. Create Graph, goto "Customize Control"
2. Then in Customize Control Window, switch to "Change to Edit Mode".
3. Select the Scale Legend Array, and then select from Pull Down Menu "Edit -> Customize Control"
4. Now you have opened another Customize Control Window, but just with the Scale Legend Array. Here you can right-click the scale-string and select to hide that string.
5. now go back, close the Customize Control Window of the scale legend, select to replace the scale legend, and voila: scale string is still hidden, just what you wanted
See also the thread here:
http://forums.lavag.org/Hide-text-label-in-graph-scale-legend-t14187.html#entry63629
08-07-2009 02:20 AM
It works, Oskar!
I've been searching for a solution of this problem many times. It appeared finally.
Best regards, L.
