problems with write to measurement
My project group has some problems with the write to measurement VI.
Firstly, for each of the SOC/Voltage...each file only has one value, how to make all value inside one file?
Secondly,How to make all the different  parameters, such as SOC1, SOC2, Voltage1, Voltage2, appear in one excel file for easier reference?
(2,180 Views)
Look at your settings for the Write to Measurement File.  You are telling it to save to one file, and then use next available filename.  Try append to file.
Also, use Merge Signals to combine the 4 and write to a single Write to Measurement File.  Right now you have 4 identical ones with the same file name.  They are stepping all over each other.
When using the Write to Measurment File, try opening up the help file and reading it o understand what each setting does.
(2,169 Views)
