03-12-2012 08:52 AM
hello,
I would like to develop an app, which would find out the total no. of rows and columns from a given excel sheet and read out the data in the same. I have made use of few vi's I found on forum, but having trouble runing them,
can anyone please suggest me what could I be doing wrong? I have never used activex before...
Solved! Go to Solution.
03-12-2012 09:55 AM
What error you are getting, when you are trying to execute it.
03-12-2012 09:58 AM
03-13-2012 10:55 PM - edited 03-13-2012 10:56 PM
Hello Puneet, I am usnig the same example as the link you posted.
I would like to perform foll:
The user would enter data into an excel file and I would like to read the same in labview program. Since the no. of rows and columns of the data file is not fixed, I would liek to find out
the no. of rows and cols first and then read the entire file.
03-14-2012 07:14 AM - edited 03-14-2012 07:17 AM
I would have used the Free Excel Toolkit. See some example with it here, here and here.
The library contains premade Excel ActiveX functions. This function right here would have helped you alot:
03-19-2012 01:53 PM
Even Deejay, what about the data in the excel sheet? how to extract that?? I can find the last row and column, ...
03-19-2012 02:01 PM
Also, i downloaded the toolkit you made, how can i use it? how to install it?
03-20-2012 02:23 AM
Hi
Yesterday I sent an email to a guy, explaining how to install it. Download the toolkit and the instructions I have attached and you should be fine.
03-20-2012 05:14 PM
awesome.. taht helps...
g8 job 🙂
04-25-2012 08:57 AM
You can also check ou tthe Excel Active X board where many items and examples are avaliable: There is really great stuff in there.
http://forums.ni.com/t5/BreakPoint/Excel-Board/td-p/379682
