07-02-2015 03:18 AM
Bonjour,
Ma question est peut être vague mais quelqu' un pourrait il me dire c' est quoi cette erreur de tag . Comment le corriger?
Erreur lors de l'analyse de l'objet Commande table. Il manque un tag.
Ligne 606:"
<STRING>Temps</STRING>
<STRING>In</STRING>
NB: Monfichier.log du noeud de propriété import txt
Merci
07-02-2015 12:33 PM
S'il vous plaît fournir une partie de votre programme LabVIEW afin que nous puissions comprendre ce qui pourrait être la cause de l'erreur . Nous avons besoin de plus d'informations que vous avez fournies.
Cheers
--------, Unofficial Forum Rules and Guidelines ,--------
'--- >The shortest distance between two nodes is a straight wire> ---'
07-02-2015 09:26 PM
07-07-2015 07:37 AM
Hi ,
sorry for delay to reply and i can' t share the vi because it's not my proprety. After an analyse , i think that LV have many limitation or bug...""I THINK"". I explain:
Firstly i create a simple vi with one led and i did a program with one method node import then export...The functionnement was correct.
Secondly i replace the Led with TABLE (i put some value in the table) and i did the same test . the export is correct but when i try to import the text i have error in log file.
You can try this if you like ..
Therefore i understand why my program have an error .I have a table in my front panel.
Thanks for you help if you have suggestion.
regards
07-07-2015 07:57 AM
You can use this vi for do the test ..first export then import and look the log files
07-07-2015 09:21 AM
I can't recreate the error you're seeing. Can you provide a simple version of your VI that causes the error? just sending the Export method doesn't give us enough information because it sounds like the VI you are using is causing the problem.
Cheers
07-08-2015 03:47 AM
Hi James and thanks for you help,
Now it is clear. If you import a .txt file from your front panel ,you must not change this front panel. For example if you have one led in your front panel , before export .txt, you must not add anything in this front panel otherwise if you import .txt ,there are error.
It's why i have error. My table is empty if i export .txt file and before import i writte in this table .
I hope you understand what i say.
Regards and confirm if it's right.
thanks
