04-22-2015 09:26 AM
When I dismiss the probe watch window, there is (by default) a "Are you sure?" dialog. There is also a "do not ask again" checkbox. I checked this box a while ago, but now would like to be asked again. I cwould like to find out how to un-do this choice, and turn the dialog back on.
Thanks!
04-22-2015 10:21 AM
Open your LabVIEW.ini file, and fine the line:
WatchWindowDoNotAskOnClose=True
And remove the line and save, or change it to a False. There might be a menu somewhere to re-enable it but this is where it is stored. You may need to restart LabVIEW.
Get going with G! - LabVIEW Wiki.
16 Part Blog on Automotive CAN bus. - Hooovahh - LabVIEW Overlord
04-22-2015 10:56 AM
Thanks very much!
-Jeff
04-22-2015 11:52 AM
@JWP@sal.wisc.edu wrote:
Thanks very much!
Thanks are given with kudos, and marking solutions in posts.
