10-12-2010 11:47 PM
Hello, my name is Dimas aryo, student of Institut Technology of Bandung..I'm still doing my final project.. my hardware is USB-4432..I have succeeded to build Triggering program, and can start taking data at certain level ( 0.2 Volt )..but i'm still confuse how to see the data at certain seconds before start taking data ( Pre-trigger ). I'm using DAQmx for the driver..and LabVIEW8.5..
Your help will be aprreciated.. better that you can attached it..
Thank you very much guys... GBU All...
10-13-2010 05:19 PM
Hello Dimas-
I think what you are trying to do is use a reference trigger. From LabVIEW, select Help»Find Examples. Once that opens, take a look at Hardware Input and Output»DAQmx»Analog Measurements»Voltage»Acq&Graph Voltage-Int Clk- Dig Ref.vi. The digital reference trigger will wait until the number of pre-trigger samples has been gathered before it registers a trigger on the specified line. At that point, it works like a circular buffer, continuously throwing away the oldest sample as the newest sample arrives.
I hope this helps. Best of luck with your application!
10-13-2010 11:56 PM
Hello Mr. Gary,I have tried using Reference analog edge and Reference digital edge for triggering, but the hardware of USB 4432 cannot respons anything for acquiring the data... i have tried with property node of trigger, and the respons still the same.. Is it possible that we can build pretriggering program manually without using DAQmx ? .....
Thanks for your helping and attention... Gud Luck sir...
