08-04-2009 02:47 AM
08-04-2009 03:01 AM
08-04-2009 03:38 AM
08-04-2009 03:43 AM
08-04-2009 03:59 AM
08-04-2009 04:18 AM
08-04-2009 04:22 AM
Have you tried to connect an array to the Square Root Function
Owning Palette: Numeric Functions
Computes the square root of the input value.If x is negative, the square root is NaN unless x is complex. If x is a matrix, this function takes the matrix square root of x. The connector pane displays the default data types for this polymorphic function. x can be a scalar number, array or cluster of numbers, array of clusters of numbers, and so on.
Remember always enable context help (Ctrl+h), and do not be afraid to dive into the detailed help option
08-04-2009 04:24 AM
