polar plot line color
VISincrofasor.pngHello
I have three vector plotting using polar plot.vi the problem is when I tread to shift the line color, only use black, I need three diferents colors any suggestion?. I put a picture with my block diagram.
I would like too chance the line width how to I can realice this using mi VI?
thanks
Danilo
(2,126 Views)
Hi Danilo,
I think you can use color box contants in a case structure, each case sent one color constat, so you can select colors when you select a case on case structure.
Abel Souza
Engenheiro Eletrônico
LabVIEW User since 8.5
(2,098 Views)
@Abel_Souza wrote:
Hi Danilo,
Well that is part of the story but the picture input tunnel should be changed to a SR if you wnat more than one plot.
Ben
(2,096 Views)
