03-12-2016 01:31 AM - edited 03-12-2016 01:33 AM
First of all, sorry about I cannot define my problem better, but I am really not familiar with graphics handling, and picture transforming, so I can only say the result is ugly 🙂
I have a simple example png file, created from a vector graphic svg file, using Inkscape. Size of the png is 300 x 200, dpi: 270.
My problem is that, I would like to present this png picture on my front panel in good quality, in a 2D picture indicator. When I do this, the result looks "ugly" or "pixellized". Is there a way to display such png file in LV with a better quality (I have LV 2015 Pro 32bit, but no IMAQ and other similar toolkits available)? If I have a look at this png file using for example Irfanview, even after some zoom in, the picture looks good and "smooth".
Right now I use this simple way to load the png into the 2D Picture indicator:
I have also attached the png file for reference.
Edit:
when I compare the LV and Irfanview results (left is LV):
Solved! Go to Solution.
03-12-2016 03:39 AM
As a workaround I just decided to use a picture ring, since for this project I have a predefinied static list of png pictures. Looks very sharp and nice 🙂
Anyway, I am also still interested how to display a png in a 2D picture indicator with good resolution...
03-12-2016 04:45 AM
I take your png and fill white background.
There is result (bottom img):
03-12-2016 04:48 AM - edited 03-12-2016 04:49 AM
Please attach the VI, or snippet.
"fill white background" How? Programmatically?
03-12-2016 05:03 AM
Ok, i got it!
It looks like LabVIEW cannot handle png files with transparent background good. I have changed the transparent background to white using an image editor, and I get good result after importing to 2D Picture indicator.
Thanks, lesson learned 🙂
03-12-2016 06:42 AM
There is an interesting thread on this subject,
Ben64
03-12-2016 06:53 AM
