03-24-2014 12:48 AM
Hi. I have read combination of circle data from excel sheet (CSV file format) and i have collected those data in an array in front panel. Now using these data of array i want plot those circles one by one in xy graph i.e at first 1st circle will be plotted, after 5 sec 2nd circle will be plotted and so on.There are total 8 circles.So after 35 sec i will be able to see all the circles in xy graph.I have attached my vi file and CSV file.Thanks and Regards - Supriyo.
Solved! Go to Solution.
03-24-2014 02:33 AM
The Attached VI will serve your purpose
Murali
CLA
*Kudos Welcome*
03-24-2014 03:59 AM
Check this for ur problem.
03-24-2014 05:20 AM
thanks a lot. You are amazing. I am trying to understand your program.
03-24-2014 11:11 PM
Thank you. Please mark as solution if your problem solved.
03-25-2014 04:10 AM - edited 03-25-2014 04:12 AM
Hi Muralidharan,
whatever you do in your VI: you do it much to convoluted!
Is there a reason to use EXT representation for those numbers?
Why did you split the circle in two halfes?
Hint: when creating an uninitialized shift register you should clear the data in the register before saving your VI. Did you check it's filesize?
I removed the waiting part for simplicity…
03-25-2014 04:46 AM
Hi GerdW,
Thanks for your inputs.
Actually it worked fine even with "sgl". By mistake i uploaded the VI with uninilized shift register.
Regards
Murali
03-25-2014 04:56 AM
03-25-2014 05:32 AM
Hi GerdW
Can you send the following VI in attachment
Regards
Supriyo
03-25-2014 05:38 AM
