plot number of circles read from excel
Hi. I have read combination of circle data from excel sheet (CSV file format) and i have collected those data in an array in front panel. Now using these data of array i want plot those circles one by one in xy graph i.e at first 1st circle will be plotted, after 5 sec 2nd circle will be plotted and so on.There are total 8 circles.So after 35 sec i will be able to see all the circles in xy graph.I have attached my vi file and CSV file.Thanks and Regards - Supriyo.
Message 1 of 22
(3,128 Views)
The Attached VI will serve your purpose
Murali
CLA
*Kudos Welcome*
Message 2 of 22
(3,104 Views)
Check this for ur problem.
Message 3 of 22
(3,091 Views)
thanks a lot. You are amazing. I am trying to understand your program.
Message 4 of 22
(3,081 Views)
Thank you. Please mark as solution if your problem solved.
Message 5 of 22
(3,053 Views)
Hi Muralidharan,
whatever you do in your VI: you do it much to convoluted!
Is there a reason to use EXT representation for those numbers?
Why did you split the circle in two halfes?
Hint: when creating an uninitialized shift register you should clear the data in the register before saving your VI. Did you check it's filesize?
I removed the waiting part for simplicity…
Message 6 of 22
(3,039 Views)
Hi GerdW,
Thanks for your inputs.
Actually it worked fine even with "sgl". By mistake i uploaded the VI with uninilized shift register.
Murali
Message 7 of 22
(3,033 Views)
There's a small "glitch" in the picture posted above, here a corrected version:
Message 8 of 22
(3,028 Views)
Hi GerdW
Can you send the following VI in attachment
Supriyo
Message 9 of 22
(3,024 Views)
Hi Supriyo,
no, I didn't save the VI.
But it is quite easy to recreate, except for RampPattern (which might not be available in the Base LabVIEW version) all functions are easily to find on the function palettes!
Message 10 of 22
(3,020 Views)
