plot graph in
Hello uni-pixel,
The error actually states quite clearly what the issue is.
Do you know what the difference is between a cluster with 2 elements and a 1D array?
If not, then please go through the training crossrulz provided the links to.
This will help you understand the error and will also help you to be able to program this yourself.
PS: Has your teacher provided you with any training materials?
Kind Regards,
Thierry C - CLA, CTA - Senior R&D Engineer (Former Support Engineer) - National Instruments
If someone helped you, let them know. Mark as solved and/or give a kudo. 😉
Message 11 of 11
(580 Views)
