10-08-2014 02:50 PM
Hi everyone, I completed a water treatment plant project in Labview for my college course last year. I got the project finished as best I could and got an good mark.
I have tried to run the VI now but I get a message that the Plant System.Vi (sub VI) is missing. I used a sample VI for this project and moified it to suit my application.
Can anyone help me in locating this VI it would be great.
I have recently installed Labview 2014, DSC.
However, I did need the PID and fuzzylogic toolkit for my VI, but I cannot install it now as I am getting a message that I must have Labview 2013 installed first!!!
Any help with this would be great.
Regards Padraic.
10-08-2014 03:51 PM
Did you rename the subVI? Did you move it on disk? Try searching your hard drive for it.
What changed between when it worked and when it stopped working?
Did you try installing the PID and fuzzylogic toolkit that came with LabVIEW 2014? Perhaps you are using an installer from LabVIEW 2013 and it is looking for that version of LabVIEW.
10-08-2014 04:08 PM
10-08-2014 04:27 PM - edited 10-08-2014 04:29 PM
You could install LV 2013. But isn't the PID toolkit a part of the DVD's you used to install LV 2014?
Try installing LV 2014 again and see if there were any options you failed to check off when installing the LabVIEW Suite.
10-08-2014 04:47 PM
Hi, I have uninstalled LV 2014 and I am currently installing LV 2013. When I installed LV 2014 I just downloaded it, but there was no option that I was aware of to add-on the PID toolkit.
I will report back when I get everything re-installed, hopefully it may solve my problem.
Regards Padraic.
10-08-2014 09:03 PM
You are better off waiting until you receive the DVD's with LabVIEW 2014, then installing from them.
10-08-2014 09:24 PM
Ok, just a quick update, I have installed Lv 2013 and the PID toolkit, but I am still missing the Plant System.VI
This was part of a sample VI that I used from the NI website. But I cannot find it now. I found it by searching for water tank filling.
I dont have the option of receiving the DVD, just a download as im a student.
Regards Padraic.
10-08-2014 09:38 PM
That toolkit is included with the Full or Pro version of LabVIEW 2014. It's no longer offered as an addon.
It sounds like the VI you need isn't part of the toolkit. Where did you get the example VI before? Was it in find examples or something you downloaded?
Did you turn it in using something iike blackboard? If so, look at your submission to find your old code
10-09-2014 04:54 AM
Hi PadraicGranaham,
Do you remember if you "saved as" your subvi or just "saved" it? When you use an example vi and save it, LabVIEW automatically saves that subvi in the examples folder. Therefore, when unistalling LabVIEW 2013 to install 2014 that subvi could have been deleted.
Furthermore, regarding the fuzzy logic toolkit, unfortunately there isn't a version for that toolkit for LabVIEW 2014.
Please let me know if this helps and if there is anything else regarding this problem I can help you with.
10-20-2014 06:18 PM
Hi Natasftw, sorry for not getting back to you sooner about this. You are right, the sub VI was part of a example VI I downloaded from the NI website and back then when I was using LW 2013 I had to also download The PID and Fuzzic Logic Toolkit, in order to get the example VI to Run.
I cannot find this example VI any more on the NI website. It was a tank filling VI with PID control.
I lost all my of my backup files during the summer, and I done exactly what you said, I downloaded my submission and that is when I noticed that the sub VI was missing.
Regards Padraic.
