10-20-2015 04:39 PM
@Bob_Schor wrote:
if I wanted a Hotel Reservation System, LabVIEW would not be my first choice ...
If you've only got a hammer, everything is a nail. I'm guilty of this. As an ME background, LabVIEW is really the only language of which I have in-depth knowledge, so I use it a lot. I made a program for my own use at home that parses HTML strings from webpages, updates text file databases, and runs an AutoIt program. Definitely not the best way to do it, but it's what I'm familiar with and I know it'll work.
Cheers
--------, Unofficial Forum Rules and Guidelines ,--------
'--- >The shortest distance between two nodes is a straight wire> ---'
10-20-2015 04:52 PM
Please keep in mind that this is personal data and security should be a prime concern!!!
10-20-2015 04:56 PM
Good point Billko.
Personally, I've used the Blowfish Algorithm before to encrypt a data file.
Cheers
10-20-2015 05:07 PM
10-20-2015 05:13 PM
If I was a customer at this hotel, I would be *very* concerned about my personal information.
10-20-2015 05:13 PM
thank you very much for your contribution , that's what i needed to know , i asked because i didn't have any idea of the time it was going to take to search something , if you say you have tried & was really fast , i don't have more doubts . Thank you all for being so kind, you helped me a lot .
10-20-2015 06:30 PM
Microsoft SQL express has all of the security you will need for data access if set up correctly on a correctly configured network. Use Windows authentication for access, and go to Microsoft's website to see what needs to be done to protect your data. Granted this is not for the uninitiated, but it isn't too terribly difficult.
Consider taking a good Microsoft SQL class on Lynda.com. This should help out quite a bit.
LabView makes a pretty decent client for programming like this, but you might want to look at Visual Studio and try it in C or Visual Basic.net. Sadly, I spend so much time in LabView anymore that I have to stop and think quite a bit to "climb back into" Dot net, but it is an amazing platform. I just haven't been spending enough time in Visual Studio since 2008.
You could do your client in html with PHP or something similar, but you might want to look into some secure sockets to keep the data safe.
If you want to try it in MySQL look into Mamp (Apple) or Wamp (Windows) to make it easier to set up a test platform. Again Lynda.com probably has some classes on these.
