10-23-2009 06:40 AM
Dear colleagues!
Excuse me, but I need example or any help for peak detection with two thresholds. Namely two adjustable thresholds with standard peak detector for creating a detection's bandwith or range.
Peak detector have only one level threshold... But why only one...
Solved! Go to Solution.
10-23-2009 07:21 AM - edited 10-23-2009 07:21 AM
If I understand correctly, you want to set two thresholds as shown in the image below.
The top peak is easy, so no need to go into details for that one.
The peak for the second threshold (red) will be a bit more difficult to do.
You would need to filter out the signals that cross the top threshold (blue). This would be done by identifying the values as they cross the top threshold boundary. You would then need to build a "window" around them (we'll come back to this one).
You would need to define a range of valid values for the 2nd peak, which are from the bottom threshold to the top threshold. Search for the number of values that cross the top threshold plus one. The "plus one" is the one you will want to search. With all the other peaks that you do not want, you can create windows around them. The remaining one is the peak of interest.
10-26-2009 03:45 AM
Dear Ray, you are right... but may be is simpler way?
For example, I think that is better run "peak detector.vi" two times, i.e. once finding min threshold and the next time finding pulses of max threshold level.
General result of such a peak detection with two tresholds is following: "counter min threshold" - "counter max threshold"= "counter of pulses between min and max threshold."
Am I right or not? I think that it is good for finding count of pulses...
10-26-2009 07:27 AM - edited 10-26-2009 07:28 AM
I would have to experiment with how the peak detector would behave within a upper boundary. It might work. If so, it would certainly be easier. If it looks for the maximum values within an array, it might get confused with the values that belong to the peak which is above the upper threshold. What I mean is I do not know how "peak detector.vi" will deal with the values circled in green that I called interferences. See image below:
11-06-2009 04:13 AM
I'm not sure but for solving this need to write external "dll", i.e. C code.
May be does anybody know how to solve this problem??
11-06-2009 06:06 AM - edited 11-06-2009 06:07 AM
The attached VI is based on the NI Example Peak Detection and Display.vi.
Does this help you?
cheers
David
11-06-2009 08:06 AM - edited 11-06-2009 08:09 AM
Nice VI David.
Off-topic: David's VI snippet demonstrates an issue with snippets where the property nodes get changes to Strict type. To get that snippet to work, I had to disconnect the control "reference" and either create a static new Reference off of "Peak Plot" cluster, or create a new static property node.
11-06-2009 08:19 AM - edited 11-06-2009 08:20 AM
Appreciated!
Yeah, I had noticed that. It also removed the constants 0 and 1 for the two active cursor properties. Maybe they are hidden under the property node.
11-06-2009 08:33 AM
Thank you very much for your help!!
Tomorrow I'll check it.
11-06-2009 09:04 AM
David Crawford wrote:
.... It also removed the constants 0 and 1 for the two active cursor properties. Maybe they are hidden under the property node...
Yep, they are under the node. Yet another unwanted side effect.
