03-06-2007 08:33 AM
03-06-2007 10:48 AM
Dear andrej
You may think that 3min is a long time but let me tell you that my fisrt attempt was a PC application and I had 2 hours of compile time.
Ten rules to make a PDA application fast:
1) Avoid any kind of hirachy except it is impossible.
2) Don't open different windows. Use a TAB indicator instead and change the pages on demand by setting the tab value programaticaly.
3) Have all indicators and controls in one VI.
4) Do graphical actions only if nesseary. Avoid graphical updates if possible.
5) If you have to do graphical updates do it all at the same time.
6) Use a producer / consumer structure. Producer with the event structure and consumer with reactions on producer events.
Use a queue to comunicate between producer and consumer.
7) Avoid tunneling data if possible.
😎 Avoid build array functions.
9) Avoid quotient and reminder functions.
10) If you have to call external code, than do it carefully and try to do as much as possible in C. If you have to collect data avoid several calls. Try to do it in one call.
I realy hope this may help you.
With kind regards
03-08-2007 09:30 AM
03-09-2007 08:28 AM
03-12-2007 12:52 PM
Andrej:
Could you please post the VI that you are deploying to the PDA so that I can test it on my end?
Rudi N.
