07-31-2014 02:57 AM
Solved! Go to Solution.
07-31-2014 03:04 AM
Hi Rex,
when you speak of "these subVIs" you should attach them - or describe in clear words, what has changed due to changing the used PC…
Did you use TraditionalDAQ on your old PC, which is (maybe) missed on your new one?
Does MAX recognize your PCI6602 card? Can you test the card in MAX?
07-31-2014 03:26 AM
07-31-2014 03:29 AM
Hi Rex,
which files?
TradDAQ and DAQmx are completely different drivers for your hardware!
It is recommended to use (the newer/modern) DAQmx functions. That also means you need to rewrite your VIs when you used TradDAQ until now. If you don't want that (or cannot do this) you need to install TradDAQ too. It may lead to other troubles as is indicated in those compatibility charts…
07-31-2014 03:40 AM
Hi GerdW
thanks,
I have upload a atteched file, but I can not see it too. try again...
I think I know where is the problem, maybe it caused by TraditionalDAQ not installed.
but I have tried to rewrite a new vi output frequence through 6602 under DAQMAX, but not successed. do you have any example for me if possible.
07-31-2014 03:43 AM - edited 07-31-2014 03:47 AM
Hi Rex,
DAQmx comes with a lot of example VIs in the LabVIEW example finder. There are examples for Frequency output too…
Your old version used DAQmx functions as can be seen quite clearly in your picture.
The new version uses some "DAQ Pilot" functions - I never heard of such and I don't know where you got them from…
(Remark: I cannot open your new version VI due to it's LabVIEW version.)
